Guest
·Does anyone know the factory spec compression readings I should be getting when I do a comp. test (in psi)? Please let me know. Thanx.
'91 SE-R, stock and needing brakes.
First, remove the fuel pump fuse and run the car until it dies so you aren't injecting fuel.<font face="Verdana, Arial" size="2">did you open up the throttle all the way while cranking it? </font>
