Learn to swim
I have been running an Autometer a/f gauge for a while now, and it always reads rich at high RPM WOT. I installed an Apexi turbo timer last night, and its reading waaaay lean(20:1+) at the same time my autometer is showing rich. What do you think is going on?
I dont think I could be that lean without detonation/explosion...Josh
Banned
My Apex Turbo Timer works just fine at WOT............i pay attention to o2 volts not the gay ass A/F ratio **** cuzz in this case with narrow band tunning your better off readings volts as opposed to theoritical a/f ratio..........plus did u know you can make ur own a/f ratio cuzz there adjustab'e.....thats real good for novices...lol
Learn to swim
So, what are your normal O2v's? Cruising and WOT would be great to know if you dont mind...Josh
Banned
Crusing should be all over the place quickly.......mine does.
WOT should be in the mid ~.95volts range +/- .01
Learn to swim
thanks
