I think I am having the same problems with the MSD Blaster coil.
Weird, mine works ok. What ignition are you using Mike?PSSSHHHGOESMYSR20 said:Has anyone ever had any problems with this coil? I installed mine and it seems to missfire like crasy, and sputter under high boost. I had to take it out and reinstall my stock coil, everything was fine after that. Also, what coil wire are you guy's using with this also?
Thats because the blaster coil is weaker than the stock coil.NiceGuy said:I think I am having the same problems with the MSD Blaster coil.
choaderboy2 said:Weird, mine works ok. What ignition are you using Mike?
Mike
What coil would you recommend? This is on a stock DET in a B15. I dunno how I would go about using a stock coil,...should I try this Crane coil?choaderboy2 said:Thats because the blaster coil is weaker than the stock coil.
Mike
Probably the impedence of the coil doesnt match the stock ignition. It will probably get better once you install the box.PSSSHHHGOESMYSR20 said:I am using the stock ignition, I haven't put in the Hi 6 DSR yet.
The stock internal coil is pretty good.NiceGuy said:What coil would you recommend? This is on a stock DET in a B15. I dunno how I would go about using a stock coil,...should I try this Crane coil?
Use a MSD HVC Coil then, those kick ass.NiceGuy said:I am using the SR20DET motor, it has an external coil. Since we had to re-wire everything, I do not know how to re-incorporate the stock coil to work again, so I need a better coil to use than this MSD.
Mike, I belive its an GM HEI boot.PSSSHHHGOESMYSR20 said:Anyone know which coil wire to use with this coil? The stock one I have wont work.
