I had an SR20de engine that had problem starting. I repaced the engine and after 6 days the lower bearings went out; metal shavings in oil pan. I was replacing the head gasket on the first engine and had a head bolt snap in the hole; block down. Is it possible to take the crank assemby; including the pistons and put it is the second engine? I can't afford another engine although that is what I would like to do. Finances are really bad right now.
SLOW SE-R
It's the damn oil pump killing the SR20's.. It's the heart of the motor.
A machine shop will remove the broken bolt for around $25-30. It should be easy for them to remove. It's an aluminum block. Steel bolt.
SLOW SE-R
Polish the crank and throw in some new bearings... Maybe some rings too. It'll be "ALRIGHT"
I tried using an easy out on it, it snapped so now that is stuck down the hole as well. Love the car. Hate the problems.
SLOW SE-R
The machine shop can get it out. Trust me... It's an every day job for them.
