Hi all,
I'm running a red top S13 DET, RWD. The fuel injector on my number 2 cylinder has stopped working. After some troubleshooting, I have traced the problem back to the ECU itself. Has anyone here experienced a similar problem? I opened up the ECU case to check for obvious things like a cracked PCB, broken trace, etc. Everything checks out A-OK from the pin (number 110) back to what I think is the injector driver. I have no idea how to test that, so now I'm stuck.
Is this a common issue with these ECUs? If so, I might consider buying a replacement and a spare to keep on the shelf incase it happens again.
