I never ran the car with the T25. I sold the manifold, turbo, & injectors before I put the motor in. I bolted on the FMAX manifold and T3/T04E turbo before I put the motor in. What do you use the car for? Road racing? Auto Xing? I would suggest going lower compression, but I am not too sure if you would need more than the T28 or Silvia turbo. (Horsepower Wise)I have heard that above 275 hp, cars seem to have too much power for the track. I am not a road racer or auto crosser , so I could be mistaken.
Louis Anaya 1992 Sentra SE-R
13.6 @ 111 mph(Street Tires),12.7 @ 112 mph(Slicks 2.00 60' time), Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Kuhmo 205/40/ZR17 Tires
