Guest
·Guest
Hi guys, I finally got my det running but it doesn't want to idle and runs kinda rough. I found a vacuum leak and that helped it somewhat. It seems to run alright when I give it throttle but not when I back off. Also, the cooling fans didn't some on although it ran for about 10 minutes straight. The hoses became pretty hot and the temp gauge indicated about a little less then half (basicly like normal position).
The only two things that I know of that may be a part of this is I don't have the bov hooked back into the intake yet and it was leaking at idle, and I was using the de ecu.
Are there any other common reasons that would cause similar symptoms?
Thanks,
Matt Ostlund,
93NX
91SE-R DET finally running
Thanks,
Matt Ostlund,
93NX
