1 - 12 of 12 Posts
Can someone explain what my risk are by putting a DET stock turbo on a SR20DE motor, without changing anything, leaving the motor stock (no low comp pistons)and adding some jwt cams, ecu and UD pullies.. also how much is a new T25, stock turbo.
Thanks Ryan
_______
As long as you get a JWT ecu and an IC the only risks is you are going to have is keeping the car one the road from the incredible tourque steer. Your tires might suffer a little bit too but that is more fun than risky
The stock SR with 370cc injectors(I have some for sale BTW) should run fine with a JWT ECU at the stock BB DET boost levels 6-8psi.
Mike
98sentraSE Turbo
people.ne.mediaone.net/mgoss/page2.html
[Edited by Mike Gosselin (11-04-2000 at 03:16 PM).]
www.motorists.org
What Mike said
It's not detrimental at all with stock boost. I will, or course, be playing with more boost later, but NOT without A/F ratio and EGT gauges. This way I can tell if I'm running too much boost for my compression or not.
Look at Ryan Besterwich's car. He's still running 9.5:1 and he has 400hp!
That's what I always try to keep in mind
_______
WhatCrazy Ben said the De is a bold[hehe] motor. Ha! you caaaaaan run atleast 8psiIMHO with out blowing up the 9.55:cr and get 13.9+ trap times. Go get some mustanks. and be happy
Mike
98sentraSE Turbo
Nah, you don't *need* water injection to run 20psi on race gas but it's a nice safety factor. In fact we run the smallest water jet we have when on race gas and the base timing pumped way up.
The SR is a stout motor, have a ball.
Mike you get torque steer? Must be a non lsd thing, I can let go of the wheel under full power with no problems. Strange...
www.motorists.org
Jay! How much boost you think I can safely run with my setup and not break sumthin on pump gas? Asking Kojima but he's taking forever to answer
Discussion Starter · #12 ·
Sounds like a plan, I just have to save up for the Turbo, Living in SF most of my money goes to RICH landlords.. well first i have to get a new clutch next week..
1 - 12 of 12 Posts
