1 - 13 of 13 Posts
Hi guys I just need to know whats the difference between those two.
I heard that the 10:1 are flat, but are they really flat FLAT!! :tongue:
I have a JDM sr20 but I'm not really sure of what compression is it.
I'm going turbo so I need to get that straight.
Thankss!!
No D E T.
10:1 pistons are just flat across, wish i took a pic of mine. the 9.5:1 pistons have like a 1/4" border around the edge, then step down like an 1/8th inch.
it wont matter going turbo, the difference is small, but the 10:1 will help with lag a little, just spool up a little faster.
Just different!
Thankss!!
Panita
The diference in the top is not much. The 10:1 pistons are flat and the 9.5:1 pistons are flat in the center but have about a 1/4" border that is a liitle bit higher than the center of the piston ( like a very little dish ).
Pito
They're just cones!
That pic would be just a little more useful with a cleaner 9.5:1 piston... j/k.
I don't believe that little dish counts for 1/2 a point in compression.
GTRSentra said:
Panita
Pito
Hey thanks you guys!!
Pito tu posteas en carrito.net??
Ironman
Believe what you want. But you have nothing to go on.
The fact is that it does.
Besides looking at the piston, is it possible to identify 10:1 CR engine from 9.5:1?
I have just swapped in an SR20DE. The engine is taken out from P-10 Primera JDM model 1992.
Well, thank you anyway.
1 - 13 of 13 Posts
