my brother crashed his 92 se-r (frontend) the engine is fine but all the front panels would have to be replaced along with anything that was in front of the engine. i found a 92 se and i was thinking about either doing an engine and tranny swap into the se or using the frontend of the se to fix the se-r. what would be easier,if possible, an engine swap or a frontend swap?
employment whiplash, NC
AFAIK, the only major differences between the two are the engine and trans. Might be easier to transplant the SR20 into the SE. Talk about a sleeper....
Matt
92 SE-R from Heck
big worm,
My 92 has front end damage and I learned all sentra's for 92 have the same bumpers/panels. Preserve the SE-R because it also has better seats/suspension/guages/exhaust/wheels etc. Get the SE front end put onto the SE-R and you are in business.
the more i look at his car the more i realize a frontend swap is going to be difficult. it looks like it would be easier to just swap engines and trannies. do all the mounts line up or do i have to buy anything. the se is auto and the se-r is manual. also the bent so i might as well throw a header on there, anyone know where i could buy one?
thanks
G-unit
The engine mounts and the cross member have to come from the SE-R. If you really want to do it right swap the harness guages and all, although this would be a BIG undertaking. I think you can swap the pedal pod (clutch brake gas pedal mounts) out. Anyone know? Plus I don't know if the SE auto is gonna have the hole for the clutch cable and stuff. Then you have to think fuel pump , Anyone know if it's the same for 1.6l. Man the more I think the stranger it gets. Then you still don't have SE-R brakes or sway bars. GOOD Luck.
I would swap body parts. There is a reason why body work labor is less than mech labor.
