I know B13 and B14 manual transmissions use a cable actuated clutch system and the late B15 uses a hydraulic clutch. Is it possible to retro fit a B13/14 gear box to a B15. I would think that you need a clutch pedal assembly, fabricate your own shift linkages, clutch cable and probably need to be creative in the placement of the clutch cable bracket, even might have to make your own....
Any opinions, any one with any ideas please shoot...
Wilwood builds a pull style Clutch slave cylinder that could be easly adapted to the cable lever on the b13/14 Trans to make it work with the B15 Hydraulics .... As far as everything else working ... I dont know ..
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
SR20 Forum
