Straight out of the SAE Papers; spelling and all.
MAJOR SPECIFICATIONS
Type :Water cooling gasoline 4 cycle
Number of cylinder, arrangent :4, in line
Type of combrustion chamber :Cross flow, pent roof type
Valve mechanism
OHC4 valve per cylinder,chain drive
Displacement :1998cc(l22cuin)
Bore x stroke :86.0x86.0
Bore pitch :97.0
Block height :211.3
Compression ratio :9.5
Crankshaft journal dia :55.0
Crankpin dia :48.0
Connecting rod length :136.3
Valve dia :Int 34.0,Exh30.0
Fuel system :Multi point injection,ECCS
Recommended fuel :Unleaded regular
Emission control system :TWC+ramda control
+EGR+EM
Max power :140hp/6400rpm(SAE net)
Max torque :1321b.ft/4800rpm(SAE net)
Dimension(LxWxH) :685x610x615
