My tire is used in the inside of tire (on front wheels)
I just wonder how I could change the alignment on my nx2000 ?
Is this only the free play between knuckle and strut ?
I know I can adjust tie rod but.. I never touch those, than they should be at the right place...
But I change suspension a year ago.
My tire are almost dead now so I would like to ajust alignment my self..
You adjust it at the tie rods. It's common for the alignment to change do to small camber changes when you change the struts out. If you lower the car the change is not small, it's huge. Search my post on how to do a alignment.
· I love Katamari
I went through changing camber on my egg - search the NX forum. It's real easy, you just need a level, tape measure and calculator
