I'm using Nissan's right now. I heard that VLSDs breakdown over time and the extra heat genertared requires the tranny fluid to be changed more often. I did a search and found a mention about someone filling the tranny with LSD tranny fluid. Is this the real deal?
The VLSD is a sealed unit , so regular Trans oil is fine , its not like clutch style LSD's that require a special LSD oil , also most 75-90 and 80-90's are setup to be used in all LSD units ( at least the Valvoline fluids I use !
Thanks for the info.
