1 - 13 of 13 Posts
i've ridden in jim wolfe's disco potato spec v. runs strong, mash the throttle and response is instantaneous, hardly any lag, kinda like a v8 but of course better.
iczer200sx what size is that tubing your using to recurculate the bov. i have the same bov and will need to do that soon. and how does it stay on there without blowing off?
Keeping It Real
You've ridden in it and didn't know it was a SE, not a Spec V? ;)
Actually they built 2 turbo b15s. One was the SE they built way back when and the other was a spec v they built.
Both are nice cars.
Keeping It Real
Both are nice cars.
So they have a Disco Potato Spec V or just a boosted Spec V? I know they built a Spec, but I was under the understanding that the SE was the Disco Potato because of the paint job. ;)
um, of course i know the difference. the one i rode in was red, broken motor mount, stock suspension, fuel light on, fully built bottom end, and hauled ass. =)
Keeping It Real
:) I guess I called the B15 SE that JWT had the DP and didn't consider the Spec V the DP, but in fact it has the DP turbo in it. Sorry about that. :D
Yes , I got the first one in Australia . This turbo is really good , very free flowing on the exhaust side . With this turbo forget how to spell lag because if your engine is tuned properly and the exhaust adequate the results are excellent . Only two things I found were a problem .
(1) The increase in exhaust noise esp with 3" pipe - if there was a next time I would use 2.5" , because lets face it for 280 whp all 3" tube does for you is act as a megaphone !
(2) The 3" air inlet is also overkill . I found that my charge temperatures went up noticably off boost and at lite load compared to the much older Nissan ball bearing turbo (R32 RB20) . I put this down to heat radiated into the larger back plate and compressor cover , good heat shielding should fix this .
For an alternative turbo to the std DET this turbo would be very hard to beat and would be my no1 choise . Have fun A.
Discussion Starter · #12 ·
thanks man, i've been looking around for turbos and i haven't heard any reviews about this turbo, what sucks is i just order a 3in downpipe
Yes lifes like that . Still someone may buy it . With exhausts you need to remember that the DP Turbos turbine outlet is around 48mm and 3" tube ID is something like 73mm , so the exhaust tube works out to be two and a half times the cross sectional area of the turbine outlet . Corky Bell (Maximum Boost) says that , "there is an exhaust gas velocity that ought not be exceeded " , and quotes 250 ft/sec . He also mentions that turbine outlet diameter plus 10% is a good rule of thumb ie 53mm for the DP Turbo , and thats virtually 2.25" tube ID !
The next turbo I'd like to try uses a 56mm gt30 turbine outlet so this plus 10% = 61.6mm or about 2.5" tube for 400hp . Corkys graph of pipe size versus engine hp shows 2.5" tube being good for just under 500hp . Got to go bye for now , A .
1 - 13 of 13 Posts
