1 - 20 of 25 Posts
i wanted to know waht causes the boots on the CV joint to rip????
is it lowering the car or do they just break with time????
CV joints, like brakes, wear out over time. The boots rip, dirt gets in them, and the joints go bye-bye.
Lowering your car should have no effect on them.
IMO, yes I think they will wear out quicker. Driveline angles can mess things up big time. Also age and one rock on the boots will do it.
GT30R'd Up
Dude, Give me a call when you can. Like I told you I usually take my car to get anything that has to do with my axles to Power Front Wheel Drive in Hialeah. They Replace Boots for $40 and thats with Parts and Labor Included or they'll rebuild your axle for $85 and thats with parts and Labor too. You can't beat that price with a bat. All you gotta do is give them the car.....and you sit in the funky smelling Waiting room.
Allan
www.FAIRTAX.org
Lowering your car excessively *will* cause boots to fail. Fatboyse-r had his brand new boots fail after 2 sessions at Watkins Glen. He had his car extremely low since its not really driven on the street and he has shortened struts. A always ymmv...
Whoah. Looks like I'm wrong on this one.
To add to what paNX2K&SE-R said, I think that "excessively" is the key here. My car is lowered just more than an inch, has been for two years, and I've had ZERO problems with the CV joints.
hey thanks allan!! i think me and my dad will take it apart on Friday and then ill take it to that place so that they can change the boot. I think i will be doing the brakes on Sunday maybe u can and help me and my dad if u have time.
sleeper
lowering the car excessively WILL cause the CVs to bust. All the guys racing in the NASA SE-R Cup series can probably attest to this. I've seen one of their cars and the axle is like at a 30+ degree angle or something crazy.
Discussion Starter · #10 ·
my car is lowered about 2.25in the front. Is that too low???
<>< Jesus is the Answer
Discussion Starter · #12 ·
i have the shortened struts from Motivational, will that make a positive difference?
I think you would be better off at 2" lowered.
This is my personal recommendation, so take it with a grain of salt. Also, 1/4" wont make a very noticable diffrence with lowering and how your car looks IMO.
I know how expensive axles can get and that is why I personally wouldnt take a chance with lowering a car too much. Maybe Mike could chime in more about this. In the meantime you might want to check that link out that I posted up there. It has GOBS and GOBS of great info.
Boost Addict
YES!! lowering your car will bust your boots and cause premature failure to your cv joints. I'm on my third set of axles in 21/2 years and they are already clicking.
how low did you go, and what suspension is it?
lack of sr20 owner
i was told anything over a 2" drop could will have an effect, the lower you go the worse it gets. the rubber boots act like an accordian, they rub together more the lower the car goes.
On Vacation
Allan
You are paying too much...I just got a NEW driver side axle for $53 and change. There is this local auto parts store (New Jersey Auto Parts) down here in Cutler Ridge. You take them your axle (for a core) and they give you a new axle for $49.99 + tax.
Manny
GT30R'd Up
Manny
You find Somewhere that will take off and Replace you Axle OFF YOUR CAR for $30 in labor. I dunno about you, but I think the time is takes to take off your axle is worth the $30 to do. Those people charge $85 to personally put your car on the lift.....Take off your wheel....Take out your old Axle....Replace it with a Rebuilt Axle.....bolt your wheel back on and take it off the lift. And Thats the same with the boot replacement, They put your car on a lift and Replace the boot for $40. So They'll probally charge alot less if you bring them the Axle to replace the boot, but you're better off just walking out of there with a fully rebuilt axle.
Allan
Wiggatastic!
Allan
Its really not that hard to take an axle out though....
Boost Addict
I've had these Eibach Pro-kits on three different sets of struts. First tokico, then gr2's now agx's. I'm finished with these 'poor-kits'. I'm goin Ground Control next.
1 - 20 of 25 Posts
