1 - 20 of 118 Posts
streetracer
Drag Pulsar GTi-R-600+whp 2011?
Hello new on this forum but thought only share with you some of what's happening in my garage just outside Stockholm in Sweden.
Are building on a pulsar GTi-R a little bit to fit me a little better.
The car will be used to street race (1 / 8 miles) but will also run 1 / 4 mile course.
engine spec so far is:
CP Pistons 86mm
Ealge stakes
ACL bearings
ARP bolts for the most part
steel cylinder head gasket
Piper cams 285 degrees and lift camshafts 11:13
adjustable camshaft drive from pipercams
Tomei rocker arm stoppers
brian crowr valves and so on
The gearbox is from Par-Engineering. A straitcut dogbox with 5th gear replacement cuff. All bearings are replaced with new, just as all oil seals.
My English is not the best but try to understand me anyway:)
The interior of the car is nonexistent, a chair, a steering wheel, dash a log and nothing more. also moving back the seat 20cm.
this is supposed to be a clean and nice drag race machine.
Upload photos so I hope someone finds my project intresanta and will follow it.
Want to say a big thank you to Gerard on the Par-Engineering and the PBZ.se
Hope you like the pictures:)
the begining :p
will be fiberglass bonnet and alot more to save weight, like plastic windows and so on.
hope you enjoy it :)
// Robban
slave to the grind
very neat build! looks like it will be a monster on the street!
streetracer
Discussion Starter #5
thanks so much!
very nice that you like it:)
some more info for those who are interested.
target weight of the car is around 1000kg, ready with a full tank.
if I tell you what I hope to ride with the horsepower, you will laugh, they have done in other forums GTi-R: P maybe just because they failed themselves: P
Hoping to land at about 650 wheel horsepower.
sit and try to think of a good solution with micro switches to avoid using the clutch and let the gas escape when I switch gear. wish I can keep full throttle, but breaking the ignition, which makes me lose torque in the gearbox and should be able to switch without a clutch or not to release the gas, but must get ignition direct again for not wasting time: P
a bit to think about. had any easier with a sequential gear lever.
some clips from the contest, I built the car to compete in.
this is some of my conflicting dates ;)
1/8 in 6,5 sec or lower :p
hope to be there fighting for the title in 2011;)
/ / Robban
slave to the grind
that looks like street racing! :-0
streetracer
Discussion Starter #10
[quote = Groudy , 2538613 ] ledsen att jag måste säga det men din överstycket är fruktansvärt! har du gjort *** själv ? ? [/ QUOTE ]
what were you thinking then?
cylinder head has been run on the flow bench and flow of well over 1000 wheel horsepower, which will suffice for my 750hp.
fun that you walk and read on my building and have opinions:)
cylinder head is processed by RaylonRacing here in Stockholm, do some work for teams in the Swedish Touring Car Championship.
// Robban
[Quote = pmdgtir , 2538609 ] omg
omg
i want to do all of that minus the cage
not practical for a daily car : D [/ QUOTE ]
hehe no this car wont be a daily driver, :p
fun that you ejoi the car anayway :)
hehe yes, street racing, the cave is very strong here in Sweden with several different major "championship" or what to call them, with several races where you collect points to the end of the season decided:) where Birka Cup is the tournament where there are no rules at all, you may run with vadsom Hallsten on four wheels with the power and the tires any moment. second cups are regulations on tiers
//Robban
A Salvadoran in Sweden huh. I guess we spread to all corners of the globe, cool :biggthump
#TranceFamily
Awesome Build!! It's going to be a beast once its done :)
Thats what I said too hehe. Good to see a fellow salvadoran in europe :)
nice admire your effort you have put in very nice job
streetracer
Discussion Starter #17 (Edited)
check out the guys here in Jamaica they got a very similar project has gone 10.2 in the 1/4 recently with problems
http://www.wheelsjamaicahost.com/wheels_forum/index.php?topic=99110.0
here is another link to it from Mazworx blog
http://mazworx.wordpress.com/2010/07/06/pulstar-goes-10-2145-letting-off/
that is just so cool :)
awsome cars. 10.2sec at 1/4mile is realy fast :)
do you know what kind of gearbox they are using?
//robban
I don´t know. May be your head is good enough for 1000hp but this head looks better ;-)
Which turbo you run on your engine?
that cylinder head look great :) real engin pornography ;)
i´m not sure which turbo i´m going to use, thats a later problem :p
but when i know, i will post it here :)
//Robban
thanks alot. always fun when someone appreciate it :)
hehe thanks alot! I realy appreciate your nice words :)
hehe a beast :p hehe i´m trying, and hope so :p
//Robban
will keep sending pictures and updates to this thread.
realy fun to share my project and pictures here :)
//Robban
its funny to think that people over seas like to swap to left hand drive when we over here are always looking to go to right hand drive. nice build dude should be a real monster, keep us posted
Gerry
1 - 20 of 118 Posts
