1 - 9 of 9 Posts
There was nobody there last night so I got to run just as fast as I could return to the starting line. It was sweet. I ran about 12 times in 1.5 hours then I left.
Best ET:
R/T .819
60' 2.311
330 6.260
1/8 9.549
MPH 74.41
1/4 14.788
MPH 93.54
Fastest (last run and coolest, ~75 at 7:48 pm)
R/T .775
60' 2.303
330 6.275
1/8 9.557
MPH 74.52
1/4 14.792
MPH 93.71
I was running about 26 psi in the front tires. I lowered it to 23 but I had wheelhop so I raised it back to 27. I'd rather be slow than break my tranny. I need a limited slip and slicks, but that won't happen until next year.
1999 Sentra SE
PRCAI, ES and homemade motor mounts, JWT S3 cams, Courtesy Rear strut tower bar, ACT S/S clutch, ZEX (JUN) 9.5lb flywheel, Hotshot 3rd Gen header, Shortened Courtesy B-Pipe, Dynomax Ultra-Flo 2.5" muffler (no tip), JWT ECU with S3 program, AGX on stock springs (for now), Axxis metal masters, Motul brake fluid, 91 SE-R drivers seat with 91 SE-R passenger seat lower cushion and 99 SE seat belt buckle
1991 Sentra SE-R in garage on jackstands (for now) with 1999 SE drivers seat
Living up Boost
Jason,
That is great! Way to go! 14's!
P10 Geek
Waaaabaaaaam!
Jason,
You said you thought it was a mid to high 14 sec car. Well now you know for sure. Hell, I could tell it was below the 15's when you let me drive it the other night.
Nice runs! Now if I could just get the G to do that, I'd be happy as hell.
Brandon
'96 G20 ($tillen/K&N intake, '91 intake cam, 17 degrees)
JordanWhiteMusic.com
SWEET! Congratulations, I'm very happy for you.
We have almost identical mods except you have the JWT ECU and the Flywheel. I know I need the ECU badly, it's all thats barring me from 14's.
Also, your trapspeed is really damned good. My best so far was 90mph.
Stormy
'98 SE(R) w/ HS CAI, HS G3 Header, Custom 2.25" Exhaust, JWT S4 Cams, UR Pulleys, KYB AGX's, Eibach Spings, Courtesy F&R STB's, ES Mounts, ES control arm bushings & shifter bushing (NI), Brembo X-Drilled Rotors w/ Axxis MM Pads, 205/50 Pirelli's, Nis-Knacks goodies
www.WhiteLineRacing.com
You like that, dontchya?
Wow! Sweet runs! With slicks, you could cut a 1.8 60' with a good launch and that would at least put you down to a 14.2 based off your current times. You might be able to get a 14 flat since you're putting down power faster with the better launch. With limited slip, you could be in the 13s!!!
Good luck!
Antonio Garcia
91 SE-R w/ lots of stuff
a slow [email protected] on JWT 50 shot
Bay Area, CA
[This message has been edited by AntonioG (edited 09-02-2001).]
<font face="Verdana, Arial" size="2">Originally posted by Storm88000:
I have about the same mods as you too storm. The only differences are that I have S3's and flywheel but no pullies. I too do not have an ECU at the time(I do now). My best mph was 91.6mph.
1 - 9 of 9 Posts
