Anyone have an idea to why my drivers door light just truned on (the light on the dash) i chucked it in reverse and now it wont go off. All my doors are shut but still on.
Where are the sensors??? Or would it be something loose behind me dash?
Banned
Check the drivers door switch. Try holding it in with your finger and see if it goes off. If it does then the door may not be in full contact with the switch.
Banned
the sensor is on the door jam near the bottom. should be a switch covered with black rubber.
Hey hondakilla, if pushing in the button doesn't turn the light off, then most likely the button is faulty - it's the only "moving" part in the whole system so it usually wears out before anything else......
