1 - 20 of 30 Posts
My Ass, your face
Several months ago, Eric(93serpilot) pointed out that some people had used dry ice to pop out small dents in their body work. Until recently, I'd never gotten the chance to try this neat little trick.
I managed to get ahold of 2 chunks the other day and applied them to some small dings and dents to see if it worked. The theory being that the extreme cold of the dry ice and the temperature difference of the metal would cause the dent/ding to "pop" out. It works, to an extent. 3 minor dings I had completely disappeared. 1 dent of about 3 inches on the back drivers side corner corrected to about 1 inch, and a small crease on the door of about 4 inches in length disappeared.
These weren't very noticeable before, and it looks much better now. I wasn't quite sure how to apply the dry ice and exactly where, but it did okay. It probably would have worked better on a hot day(90's) rather than in 50 degree weather. So, I'll try it again when it gets hot.
Just thought I'd share.
Peace Out,
Mark
My Ass, your face
Serban, I rubbed on the dings and also the circumference... didn't really know which was appropriate. Problem is, I could make a "case" for either method working... so maybe it doesn't matter. I really do think it'll make a bigger difference when the weather gets hotter and the car's been sitting in the sun.
I'm also thinking of seeing if going at a small dent or ding from inside the panel, rather than just on the outside... we'll see, come May or so.
Another point, too. If you want to get some Dry Ice, try your local supermarket. You may be able do score some for free.
Peace Out,
Mark
Seeing red
I tried some dry ice on some dings, and it worked a little.
I noticed if the ding has "creased" the metal, it will make the ding shallower, but not take it out. If the dent is completely round, it could help. It's worth trying when a bag of dry ice is only a dollar at the grocery store.
I recommend trying it, but wear gloves. Holding dry ice with bare skin for very long can be like getting frostbite in a hurry. Cold stuff.
Master Cunnilingust
You can accomplish the same thing using a propane torch, but it's a lot tricker and easier to screw up. If you over heat it it'll actually make the dent worse.
no..its not my daddys car
I really need to try this!
I need me SE-R
Okay, everyone...do this on a HOT summer day. Let your car bake in the sun and then do this. Will work out great. This is what many body shops do.
The torch thing works great if you know what you are doing. If not, you can make it that much worse. So, I recommend the HotSummerDay bit. Works wonders :D
SouthPaw
I think I'll try this, however I heard by doing this thins the metal at the applied spots and too much will make a hole rather than fix the dent
Banned
Its A Old Trick Works Better On Older Cars But It Will Work Better In Warmer Weather
I'll wait til it gets nice and hot errrr I'm in Oregon, better make that nice and warm, then I'll try this.
hummm this is very interesting.
could this also work with like co2? thats a little easier then dryice, but then again i have never tried a super market. who do you go talk to? the fish counter people or something?
i can't wate for warm weather now, i can try to get rid of those 3 little dents that piss me off!
-Dan
www.FAIRTAX.org
Dry ice *is* co2 :)
-Dan
-John-
The easiest place to get dry ice is an ice cream shop. Last summer I was expiermenting with dry ice bombs and found it at most ice cream shops and party supply stores really cheap.
yea i know dry ice is co2, i did make it through 7th grade science class ;)
i was just wondering if co2 from like a paintball tank would get the job done =P
Dan
www.FAIRTAX.org
Aaahhh I didn't think about it that way lol. Thats a pretty good question. I wonder what the temperature difference between the 2 forms of co2 is?
Dan
mhmmm
what about the air in the can? if you turn it upside down and spray it out it is co2, that might work?
Master Cunnilingust
I think you usually apply the heat slowly and gradually from the other side of the panel and watch carefully to see if the dent is getting better or worse. Obviously this wouldn't work on dents that you can't get to the bakside of. I'd do the dry ice technique first and apply it only to the very bottom of the dent if possible, which would be easier from the backside of the dent. You want the metal of the dent to contract but not the surrounding metal.
1 - 20 of 30 Posts
