something is makin a mess, i see spots the size of a fist every mornign when i go out to start the car, its so sad, anything i can do to pin point the problem
If it is leaking that much you have a pretty good chance of finding it fairly quickly. Check you filter first like he said ^^. Then get underneath the car and clean the area around the oil pan. While you're there you might as well clean around the tranny case. Come back a little later and trace where the leak is coming from. It could be your pan or even a leak from the tranny.
What color is the "mess"?
check the front main seal too where the crank pulley is. Mine leaks from there. If it's from the pan, you hsould be able to see it and fix it fairly easily
Tired!
My drain plug was leaking cause the crush washer was crushed to nothing and it wasn't sealing well. That is a spot to check as well.
Brent
