It won't work, and I wouldn't bother swapping harnesses, either. It's OBD1 vs. OBD2. '91-93 SE-R/NX/G20 cars can use the same ECU, '94 SE-R has it's own, '95-'97 SE-R and '94-'96 G20 have their own. You'll need to get a turbo program for your ECU anyway if you're going with a DET.<font face="Verdana, Arial" size="2">Originally posted by MauiBlueGride:
I use a 97 JWT ECU and just plug it into my NX harness and drop the DET into it or do I need to swap harnesses as well?</font>
I don't see why it shouldn't, unless you'll be using a different turbo, or something.<font face="Verdana, Arial" size="2">Jusssssst a question... Also I have a 1.5" downpipe for the 200 - will it work with the NX?</font>
--Andrew Phan
1993 NX2000
1998 200SX SE-R
