1 - 20 of 28 Posts
Criminology
Here's my dyno sheet.
T-25 on usdm motor, stock maf, NO CAMS 370's Calum ecu with sfac, no cat or egr. 3inch cat-back 2.5 downpipe. Boost was at 10 psi
Before the tuning I was at 206whp.
[/IMG]
very nice... what boost pressure
Criminology
Discussion Starter #4
10 psi
ooooh... :D
3 bar too... nice.
sleeper
Nice! now just add some cams and you'll make the same power at ~7-8 psi :) You'll probably want to upgrade the fuel system though... gives you more headroom.
Criminology
Discussion Starter #10 (Edited)
A/F after final tuning??
Cheers-
Erich
They told me high 11's to play it safe. This car is roadraced
which calum product?
u13 ecu i bought from a forum member
cams are in the works. I'm running a walbro 255 pump with 370's and a nismo fpr. That should hold me down
Retired for now...
holy ****...let me get this right before the ecu you made 206 and now its like 245???
Or did you actullay tune...??
Reason im asking cuase when i had the program in the car it ran real nice...then went real time with a jwt tune and loss 20 hp....so i went back to the tune i think you had on your ecu...and gained 17 back....with a 11.5 a/f
Good job though...btw its Calum not Calium...lol
I like Calium better, i think ill use that. Thats great man, 10PSI on t25 is tickle for that motor, Go up to 14psi, its good on pump gas. That should make you some nice power. BELIEVE IN SR20.
I boosted 24psi boost on Completely stock motor on race gas, and 16 on pump. YOU CAN DO IT!!!!!
Retired for now...
lol on the Calium...
now this 14 psi on pump gas on stock det is where ill be going next...
Criminology
Discussion Starter #15
holy sh*t...let me get this right before the ecu you made 206 and now its like 245???
you gotta clear your pm box, Yea, i gain more horsepower after the ecu and tuning. Its was 235, not 245.
I'm gonna stay it 10psi. I heard thats the max on a stock sr20. Correct me if I'm wrong.
Criminology
Discussion Starter #17
SR20DE can hold more than 10psi. Depending on the fuel you have available you can go up to somewhere 14-15psi easily.
would I have to get a different wastegate, or will just a boost controller work so I can go past 10 psi? My current wastegate now allows up to 10 psi.
SR powered S13 coupe
If your doing track days with the car I would leave it right at 10psi. I ran the T25 setup and then the T28 setup right at 10psi and never had any mechanical failure in 5000 track miles over a period of two years... just my 2 cents :)
Criminology
Discussion Starter #19
thanks, will do!
1 - 20 of 28 Posts
