1 - 20 of 21 Posts
Track Whore
Guys,
I finally got a printout of the dyno run. I posted it here
http://www.geocities.com/n_dahi12/s3_c3.jpg
Please tell me what should I do next. The losses are pretty high.
Naji Dahi, aka Red Mist
[This message has been edited by nj1266 (edited 09-12-2001).]
Track Whore
I give up geocities is not working. This SUCKS
former pulsar car whore
It works, you just have to copy the link and open it in a new window.
97 Super Black 200sx SE-R
Hotshot CAI, custom 2.5" catback with dynomax super turbo muffler, Hotshot header, UR pulleys (2 set), JWT ECU, Stillen FSB, Courtesy RSB, V-Racing Buzz seat with custom seat bracket, JUN CAMS (264's 10.5mm lift)
Track Whore
Discussion Starter · #10 ·
<font face="Verdana, Arial" size="2">Originally posted by silversx:
dude, looks like you lost torque..
I lost torque and hp from 0 to 6500 rpm. Sucks to be me
Are Mike K's C3 dyno numbers and charts available?
Why don't you post the numbers for jesus' chariot over on clubsi in the si vs all forum. Show them your nissan supremacy.
[This message has been edited by WhiteSER (edited 09-12-2001).]
Track Whore
Discussion Starter · #13 ·
<font face="Verdana, Arial" size="2">Originally posted by WhiteSER:
Oh how nice. Dude, don't think for a minute that my car will stay low on power for long. It is just a new learning process that I have to master.
Track Whore
Discussion Starter · #14 ·
<font face="Verdana, Arial" size="2">Originally posted by 97 Black SER:
Mike K. has a fully built engine. His numbers do not translate to a bolt-on engine with cams only.
Yeah, I know, but that wasn't the question. Are his dyno charts online anywhere?
Track Whore
Discussion Starter · #16 ·
Sorry, I misunderstood. Check the Mailing list Archive. I believe Kieran has posted the numbers as a comparo with Jack's car.
Just for those who are curious, here is a dyno chart of Rob Cadle's car with the C3 cams (the chart contains runs performed with three different ECU programs):
http://groups.yahoo.com/group/SoCal-SERCA/files/C3%20rev%20by%20CAG.gif
I remember something being mentioned on the mailing list (although in reference to S3 cams) about a lot of mid-range torque being lost with incorrect cam timing. This may be your problem. Looking at your chart (and I don't claim to be any sort of expert, by the way), you car is probably going to be only marginally faster than it was with the S3 cams, unless you fix this...
If you do decide to go with JUN cams, I look forward to seeing your results, as it seems that people are getting good results with them. Now, if only somebody knew anything about the Toda cams...
GUPAMF 4 Life
No worries Naji, we will get your power back up soon enough. How did adjusting the timing go? I need to get back to you Friday night about dyno tuning.
Terrin
92 SE-R
Track Whore
Discussion Starter · #19 ·
<font face="Verdana, Arial" size="2">I remember something being mentioned on the mailing list (although in reference to S3 cams) about a lot of mid-range torque being lost with incorrect cam timing.</font>
According to Clark, these cams do not require cam timing adjustments. They are ground to the specs that Rob used AFTER he adjusted his cam timing. But Rob and I have two differernt port designs and maybe cam adjustment is necessary.
<font face="Verdana, Arial" size="2">This may be your problem. Looking at your chart (and I don't claim to be any sort of expert, by the way), you car is probably going to be only marginally faster than it was with the S3 cams, unless you fix this...</font>
You are exactly correct. If these cams do not improve power beyond their curent state, then S3 cams are much better. Keep in mind that the 147 that I recorded with the S3 cams was W/O the ECU. With the ECU I would have been at around 150 hp. So the C3 gain are close 7-8 hp in the current tuning state.
<font face="Verdana, Arial" size="2">If you do decide to go with JUN cams, I look forward to seeing your results, as it seems that people are getting good results with them. Now, if only somebody knew anything about the Toda cams...</font>
If I go with JUN I am going all out. I am going to become the JUN Posterchild
Their cams, computer, cam springs, flywheel and dyno tuning will cost me around $3500. But that will be after I exhausted all possiblities to tune the C3s.
Track Whore
Discussion Starter · #20 ·
<font face="Verdana, Arial" size="2">Originally posted by 92SE-R:
Terrin
92 SE-R
Well I retarded the timing like you and I discussed over the phone. The car felt better. There is less bogging in the low range. There was a flat spot between 4-4.5K. Beyond that the car pulls better than before. I Will put it on a dyno on Friday afternoon. My brother will come with me since he is leaving work early. We will do a full ignition timing sweep. After that you and I and the others will do the cam timing as agreed.
I am looking at this as another learning experience even though it is pretty costly.
1 - 20 of 21 Posts
