plyin
<font face="Verdana, Arial" size="2">Originally posted by RollcageSR20:
One way to find out is to clean out the EGR and BPT. However, I don't see how the EGR could affect dyno readings, since the EGR is shut off during WOT (ECU is in open loop mode at WOT, also.)</font>
<ghetto mode on> We somehow stripped the EGR fitting that goes into the header, so what i did was this, cut off the egr tube at the solenoid, blocked off the solnoid(so its not longer functioning) and i jammd the fitting into my header as best i could for now, with the remaining piece of tube coming from the egr fitting i stuck a piece of heater hose over that and stuck a socket extention in that to plug it(its all i had layin around!!)<ghetto mode off> So right now i have a leak there, cuz i didnt do the greatest job pluggin it up, and i ALSo have a leak on my downpipe where there is a hole for a EGT probe. They did not send me a plug for that so i just suck a screw in there for now, which i know is not the right size, bu its all i had layin around. So, i know i am hurting there, cuz i can hear the leaks when i get on it hard. Im having a frend weld both holes shut for me, when i have time. I only dynoed this weekened cuz i wanted to, i wasnt expectng anythign spectacular.
Also, the stock exhaust system becomes a restriction point once cams have been added to the mix. I'm sure if a free-flowing muffler was used, a few HP could be had.</font>
I know that, and i had plannd on buying a Greddy form someone not long ago, but it fell through. I had the Courtesy, but 2.5 inch pipes are no good on a NA sr20, trust me plus it was just plain ****in loud.
The JWT S3 and S4 cams DO NOT like advanced timing. 15 degrees seem to be the optimum setting for the JWT S3/S4 cams, however, the next time there's an opportunity to dyno again, I would try it at 13, 15, and 17 degrees to see what the car likes. </font>
I have my timing set at 15 degrees, and this has ben verified by more than one person, so its right.
Another thing to check would be tire pressures and the alignment. Extreme toe-in or toe-out could skew dyno numbers by a few HP. </font>
Checked my tire pressures before i left for carlisle and they wee god. Alignment is fine.
Also, the cam timing might be off, although it's unlikely if the install went without any mishaps, or monkey dung.
Cam timing is right on. When i first did the cams car wouldnt start, went back in and check and it was off by 2 rollers, i fixed that. car runs fine.
FYI, my SE-R made 143.8hp and 128.4lb/ft with the S3 cams and the JWT S3/S4 ECU program and the rest of the bolt-on's. So, I would hope once all the variables have been checked, and you've upgraded to the JWT ECU, and a free-flowing muffler (or full cat-back), you should be at least in the high 140's/low 150's for HP, and low-to-mid 130's for torque.</font>
In the next couple months i will be getting the ECU, and a Greddy. I will also be callin JWT up and ordering some cam gears, cuz i want a litle more low end(thats where the s4's hurt). Kojima said he got a couple horsey power advancing the exhaust cams 2.5 degrees, so im gonan try that. Hell they cant hurt for 150 bucks. The holes in my header are hurting the torque i think, i dont think ill gain hp when i fix those up. We'll see.
[This message has been edited by RPWSER (edited 05-07-2001).]
