Status
Not open for further replies.
1 - 20 of 93 Posts
VZR Conversion
Another HID Group Buy this time with slim ballast !
Price :
* Single Beam-$125 shipped in United States only.
* Hi/Low Beam Moving Kit -$165 shipped in United States only
Minimum Quantity Needed :
* 6 Kits Total ( will start collecting payment and shipping out at 6 kits )
Group Buy Deal Ends Date
August 23 2008
Payment Due Date
As soon as 6 kits are met
Paypal Address
sales at liuspeedtuning.com
When making payment, please put your name, address, phone number , bulb style & color and forum sn!! THIS IS VERY IMPORTANT YOU DO THIS FOR IT MAKE THINGS GO FASTER AND WILL MAKE YOUR SHIPMENT GO SMOOTHLY !!!!
* Click here for your bulb size
* Features:
* Strong and rapid startup
* High brightness: can reach 3,600LM
* Steady brightness
* Good performance with high and low temperature resistance
* Plug & play
* Water-proof
* 1 year warranty
* Parameters:
* Input voltage rage: DC 9-16V
* Rated voltage: 12 V
* Max. start voltage: 23kV
* Input current: 3.1A+/- 5%
* Output power: 35W+/-2W
* Luminosity: 3,600 lumens
* Working temperature: -40 ~ +105°C
* Color temperature: 3,000K - 30,000K
* Life-span: 3,500 hours
* Startup time:
* Can reach 20% of the standard brightness within 1 second; can reach 80% of the standard brightness within 4 seconds.
* Auto cut-off:
* Once there is a short circuit or open circuit, the ballast will
* stop working automatically.
* Protection voltage:
* When the voltage exceed 19V, the ballast will stop working
* automatically, and make the output power below 45W, to protect the ballast and
* bulb from damage. When the voltage is 8V, the ballast still can work normally,
* but when the voltage is below 7V, the ballast will stop working to protect the ballast from damage.
* Reverse polarity protection:
* The ballast will stop working automatically when a reverse polarity happens
Click here for pictures of slim ballast
Click Here for Pictures !!!
Click Here for Color Guide
VZR Conversion
Discussion Starter #4 (Edited)
awesome thanks guys ! looks like we have a total of 4 people.
here is the list so far
Ak1m0to - g20.net
sr20 91 se-r sr20forum
negozib sr20forum
chill sr20-forum
VZR Conversion
Discussion Starter #5
bump 2 more people to go !
VZR Conversion
Discussion Starter #6
the ballast dimensions are approximately 7.6 by 6.6 by 1.66cm.
it is a metal casing around the ballast , it is a digital ballast and waterproof
JDM BOOST WHORE
dont u mean 1 more since chill is getting 2 kits? whats the difference between the single & moving kit? i also have the blk housing/ cc headlights
VZR Conversion
Discussion Starter #8
single beam - you lose high beam completely
moving kit - you have high beam and low beam both xenon.
here is the updated list chill had to drop out for personal reasons.
Ak1m0to - g20.net
negozib sr20forum
coach- sr20-forum
still need 2
VZR Conversion
Discussion Starter #9
here is the updated list only 1 kit left to go
Ak1m0to - g20.net (2 kits)
negozib sr20forum
coach- sr20-forum
VZR Conversion
Discussion Starter #11
VZR Conversion
Discussion Starter #13
yes that is correct
SE-R driver since 1994
Put me down for a single kit.
But I won't be paying till August though.
VZR Conversion
Discussion Starter #15
ok payments are being accepted today ! those that are listed above please send money
thanks !
HIOs
I'm interested...I still don't understand what actuates the bulb moving when you hit the high beam does it move automatically, once installed how does the high beam level get adjusted for height or is it automatically set it relation to the height of the low beams.
VZR Conversion
Discussion Starter #19
basically the bulb has a relay that activates some kind of magnet or motor ( not 100 % sure if it magnet or motor but i will find out) that connects to the kit and the stock harness. once your high beam activates it moves automatically aiming it (the bulb) higher producing the center hot spot higher than low beam.
once the high beam is disengaged it goes back to low beam status as nothing ever happened.
i hope that helps you out.
1 - 20 of 93 Posts
Status
