I got a code 76 (fuel injection malfunction) on my OBDII 94 G20. There is hesitation and surging under 3000rpms and occassionally dies while idling. Otherwise, it runs fine and get's about 30mpg.
Things I've changed: plugs, wires, cap, rotor, air filter, fuel filter. Disconnecting EGR has no effect.
Any ideas on what's wrong? Thanks
mhmmm
i keep reading that cleaning out that tube thats under the BPT might do the trick.. cuz i also have hesitation and surging under 3000rpms and my car dies when i press the clutch in at stops... im going to clean it tommorow... i hope i get the results im looking for
mhmmm
hey, i cleaned out that valve under the bpt and wow it did make a difference... i feel no hesitation, and that whole problem with shutting off stopped, i also hear no backfiring when i slightly let off the gas pedal like i used you... now if i can only fix this tps
I don't think that's my problem. I've already cleaned out the BPT.
No one has had code 76 appear? :(
TPS is within specs.
