1 - 12 of 12 Posts
I was trying to run a diagnostic on my ECU for my '93 NX-R (SR20DE) using info I've found for NX's from various tutorials. I've pulled out the ECU but I can't locate the screw that is meant to be next to the red LED to start the testing. Anyone know what the deal is?
The top image is a ECU from a 180sx with a CA18DET (with the screw). The bottom image is of my ECU.
sleeper
hmm..... interesting... should be in the round hole on the back of the ecu....
If you look on the sides, there should be a sticker covering the screw. That will allow you to run diagnois on the ecu.
NEOphile
Edit: didn't see the pic of your ecu... lol. It should be right there, in the hole. Maybe the AU versions didn't have that feature. Get a factory service manual, it will tell you how to run a diag. Is yours a b13 chassis? Is it the same as the American-version NX2000?
ClamSlut
Some non-US ecus do not have the screw. Yours may be like that. On your consult port jumper the top two right pins, this does the same thing.
Thanks Calum - I think your probably right. I've managed to find how to go about testing the ECU using the consult port for a N14 Pulsar (SR20DE) here in Australia, so it should be the same for the NX.
Yeh it's a B13 - almost the same as the NX2000.
There's nothing down the sides of it.
Did the diagnostic test tonight by shorting out the consult port - in the end it was very easy to do. Nothing wrong with the car according to the test... only thing is now I still need to find why it's lacking in performance.
sleeper
nizzan4u2nv said:
You know what, my stock ecu had a screw but no diagnostic light. Weird huh, maybe ill take some pics of it.
The check engine light flashes.
1 - 12 of 12 Posts
