1 - 8 of 8 Posts
alright i received my bluebird motor and the wiring harness i have had suggestions to get the det ecu but i have my SAFCII wouldn't that just destroy the purpose of the SAFCII and another question should i go through the trouble of taking the original wiring harness out and replacing it with the turbo harness is it really that hard too tune the SAFCII o yeah i am going too be running a set of 550CC injectors just in case i get the T28 turbo later..
Am i just asking stupid questions becouse no ones swap covers the wiring harness i dont want too send my ecu too JWT i just dont want to do that...
Thanks.
Criminology
you want to get an ECU set up for your program. I would not run just the stock ecu. Go with a ecu with a turbo program in it. Then you can fine tune it with the sfac. I have a Calium u13 program with a sfac.
Just with the sfac alone it still won't run right.
Correct me if I'am wrong
love the Florida sun!!
yes you def. want to get a DET ecu.
If you don't want to send it out to JWT at least consider Calum ecu.
your car will run like caca.....i also have JWT with SAFC hooked up & the SAFC is only to fine tune not for engine management, don't fall short on your investment you'll be pissed in the end if you do
agent camel toe
u wont be able to run the de ecu/safc with 550 injectors..the safc can only compensate for %55 bigger injectors
so i should send a turbo ecu too calum and have him do his magic??
or can a save some money and send him my NA ECU and make it work???
Im going too take my stock wiring out and replace it with my BB wiring harness and get my ecu when i find one tuned by Calum and rock out a wideband A/F ratio and stop playing with myself and do **** right!!!!!
Thanks guys...
CAR SLÜT
Keep the stock wiring harness, everything just plugs straight in :)
1 - 8 of 8 Posts
