Audio Nut
Ok, I've been fighting with an electrical problem for a few months now. There's a relay that keeps clicking on and off like a machine gun, battery light flickers, voltage inside cabin drops to 11.8v and my headlights flicker. If I turn the heater fan on above 1 or turn the defroster on, it stops.
The relay I believe responsible is behind the fuse box on the main harness, it's located on the top of the harness. It's black in color and is approx. .5"x.5"x1" in dimensions... does anyone know what this controls or can someone look it up in the fsm?
Help greatly appreciated...
Thanks,
Travis
Had same issues with a bad ground once.. go buy a $5 ground strap at a local auto parts store and try re-grounding from the battery to the BODY somewhere and see what happens.
Chris
Audio Nut
Chris
Hmmmm, I've got another ground strap lying around, I'll try that first...thanks for the info.
Audio Nut
Ok, tried the other ground strap and even bought a brand new ground strap, no change...%*$(%*#(@#[email protected]#$!!!
If someone can tell me what that relay is part of, it'd really help me track down the problem.
Thanks,
Travis
Audio Nut
I'm gonna go with the thought that this is the alternator going out, I've been listening in the engine bay for a similar clicking noise, but never anything until yesterday night. There was a distinct clicking noise eminating from the alternator and considering the symptoms in some other threads where the alt. was going bad were pretty similar, I'm pretty sure that's what it is. Thank god for warranties... I'll update everyone as soon as the new alt's in.
-Travis
