I put the right ones onthe front, they fit perfectly, and the bushing size for that rear sway bar is 1/2 inch but the bushing is 3/4 of an inch I went and measured it, and I a picture i saw there were four of those tie rod end/ball joint bushings wich does it actually go to, am I missing parts I ordered the master set for the car from the local shop, at the same time I ordered the solid motor mounts also but those havent made it in yet. I have a NX1600 and a NX2000 and the rear sway bars are the same size is this right I think someone swapped out the sway bars on me I think I'm going to go the junkyard and check it out. if you know something that will help let me know
Thanks, Jason
1991 NX2000 W/SR20DET SWAP,HKS INTAKE,3" EXHUAST,E.S. BUSHINGS AND MOUNTS.
NX 1600 INTAKE,AND EXHUAST
