gtir raw power
can anyone give me any suggestions on trouble shooting these fans. i changed the temp. sensor and the relay but the fans don't come on, even when the temp. goes up. the fans work i just can't figure this out. thanks""""""""
there are 3 or 4 fan relays one in the driver side compartment(under steering wheel). and two or three in relay box (engine compartment). then you also have 30 amp fusible link and fuses check all those out then if all fails,could also check fan motors but they usually don't go bad both at once.also check connections grounds etc.
gtir raw power
the only relay i didn't check is the one under the steering. is it the relay that says engine? i also dropped you a email.
man, I can't remember just woke up drinking coffee.let me know if you succeed.
Not on fire... yet
I ran into the same problem, I just wired a switch and a remote thermostatic switch to it.........
DAmn my driver side fan motor is going bust.Any of you guys have a spare for sale?I'm tinking if I could use a flexlte thin fan and wire it up to the terminal. since or fans don't seem to have fan switch.
