1 - 2 of 2 Posts
I have replaced this fuse 3 times and it continues to blow. It has lead my car to over heat twice, and I'm completely stumped. I know I can wire the fans to a switch, but I'd still like them to come on automatically, plus god knows what else this fuse is used for. Any idea why this is happening?
Thanks,
Kevin
Odds are you have a short somewhere causing it to blow. Ive blown mine 3 times already, all revolving around my stereo system. I tracked down exactly where the problem was by throwing a 60amp fuse in there and looked for smoke lol. Not the best method but it worked :)
If your fans are what is dying directly with the fuse my first place i would check would be that. Make sure you dont have any wires frayed, cut, damaged, ect. If no luck there than the hunt begins. gl bro
1 - 2 of 2 Posts
