Guest
·I need to buy some connecting rod and main bearings and piston rings for a good price anybody know where and how much I am looking to spend?
So far I just replaced my rear main seal a boy if anybody is ever going to do that it is alot more than just taking your rear main retainer off.
I figured that since I only had this car for just a couple of months that I should take the connecting rod cap off and see what the bearings look like. I took number 4 off and it showed a small amount of uneven wear so I looked at the top and the bearing was scaffed (looked like someone put a blow torch to it and sanded some of the black smoke off). My brother told me that it would be a good idea to change them and while I am at it have the main bearings done. So I am like might as well take the pistons out(head is at dpr getting some meat taken off hahaha) and put some new piston rings on. If I do all of this will I pretty much have a new engine? the intake manifold is getting cleaned up a bit also. Sorry for the long post just thought that I should let you know what all I am doing so you can answer my questions a little better. Thanks
