· www.motorists.org
Could be a rod bearing. If the SE-R list archives were working I'd find the link and post it so you could compare. Could also be an worn engine mount.
probably a mount though. it would pop and knock the whole time through the rev and get louder as you go up in rpms. just get a set of the es mm inserts and you will be ok.
A couple weekends ago I replaced the mounts on the crossmember because they were torn beyond belief(read as torn in half). What doesn't make sense, is why doesn't it do it everytime? Brian how much with it cost me to replace the other mounts? Ben, I don't really know what post you are talkign about, but I'm gonna look. IF you could find it also, I would very much appreciate it.
· www.motorists.org
here's the rod knock wav:
www.geocities.com/serban91r/rattle.wav
I took the URL tags off of it cuz it shoves an http:// in front of it and that makes it not work for some reason. Make sure this link is not preceded with an http:// and it should work
[Edited by Ben98SentraSE (10-30-2000 at 09:58 PM).]
ok I listened to that sound, and that is not what my engine sounds like. Thank Heavens not even close. Maybe it is just a mount. I'm praying that is. I won't really have time to check this week. I'll see if I can squeeze it in before this weekend. The noise is just one single pop right after the engine revs.....Night guys..I'm off to bed...
