what i have is a 97 200sx, i bought an engine and tranny from a 96 G20.
rebuilding the engine right now. don't know what to do about the wiring harness. any help or info on this swap would be very helpfull thanks.:confused:
Shift_2.0
If your 200sx is an se-r,it should be just plug and play.Same engine,both are obd2.
The valve cover is the only difference in the motors.
The tranny will have to be out of a g20T to be LSD like your 97 se-r tranny.
mine is only an se. just glad to know that all i need is the se-r wiring harness and diff ECU. very confused?? so can i use the wiring harness off of the G20 that i got the engine from? or just get an se-r harness. thanks
