Hey,
My 92' SER has just started this problem, it only happens from idle to 3k? The engine has 144k on it and has new oil in it. Could it be the timing chain tensioner doing this? Any ideas? Thanks
Kevin
www.FAIRTAX.org
Pull a plug wire one at a time and see if the noise changes. It sounds like you have a bad rod bearing. If you change it early on then you won't have to buy a new engine.
GT30R'd Up
Hey I don't want to the the bearer of bad luck but my engine did the same thing at 117k miles and now I've got a JDM DE in the car........Rod Knock is a b*tch!
Allan
