Guest
·Guest
So with that being said I'm leaning towards either a fmax stage 2, or a custom fabricated kit by Dre. Opinions?
***Andreas is a very good guy to deal with and he does very good work. I would recommend him 100%.
The F-MAX stage 2 kit is also a very good kit and will be able to get you into the 12's without question.
I've heard mention of Sr20Development.
***I am not sure about the pricing, but Chris is also a good guy to deal with and he does excellent work.
Someone mentioned to me that it's possible to swap a G20 5th gear so that you have a higher top end, is this true?
***Yes, I think I told you that a while back. The G20 5th gear has a lower gear ratio (longer gear), so a theoretical higher top speed will be possible. However, acceleration in 5th gear will not be as good.
The G20 5th gear will also allow you to cruise at a lower RPM, thus improving your gas mileage and driver comfort.
***E-mail me at [email protected] I have a lonely SR20 block and head sitting here just waiting to be used as a core for a major buildup like yours.
By the way, Andreas' number is 305-282-3643.
Good luck,
Jay Whitely
Tampa, FL
1996 200SX SE-R
GTi-R powered with F-MAX kit
Good luck,
Jay Whitely
Tampa, FL
1996 200SX SE-R
