Guest
·Guest
I've been trying to track down the cause of excessive motor and transmission movement. What do I mean by excessive? In first gear, if I make any throttle adjustment other than the most MINOR one, the drive train *noticeably* moves. The lurch is borderline scary-sever. Imagine in your car stabbing the throttle to about 50% and then completely off. It's really bad.
I've had this problem since I purchased the car 8 months ago. Initially I thought it was worn motor mounts, but I've replaced them all and the dogbone and the problem persists. I'm an accomplished driver, so I'm pretty sure I'm not a factor. Thanks for any help you can provide.
I'm an accomplished driver, so I know I'm not a factor. Thanks for any help you can provide.
