Mods list: 1997 Nissan 200sx SE-R
JGY Customs-fresh swapped Bluebird SR20DET
FMAX Turbo kit
JWT ECU
Greddy Profect B Boost controller
Ford Cobra MAF
MSD 50lbs injectors
JWT Fuel Rail
JWT Velocity stack Type 300zx Air filter adaptor W/K&N air filter
Walbro 255 Fuel pump
Garret T3/T04e Turbo w/Ball Barring upgrade
Race place motor mounts
Custom 3in Mendral Bent Exhaust
ClutchMaster 11lbs Flywheel (this has a outer metal ring gear also)
NEW Clutch Specialties - Stage 3, 6 puck sprung kit, holds 414 ft/lbs of torque - Also clutch has NO CHATTER
Toyo T-1s 17in 205x40 tires (less than 3000miles on them)
Enkie 17in RP01(less than 15lbs a wheel)
Stillen Front & Rear Strut tower bars
Stillen Front lower brace bar
Stillen Quick short shifter
Tokico Front Shocks
KYB AGX Rear Shocks
Eibach Pro-Kit Springs
Suspension Tech Sway Bar Kit -Front bar 1.0 & rear bar .75 inches. with Urethane bushings.
Power Slot front & Rear rotors
Stainless steel Front and rear Brake lines
Axis Metal master brake pads
PIAA - 1200 Fog lights
Front Clear corner lens
Stillen GTR grill
Kenwood -Dubble Din mount casette&cd player
US Acostics 80watts X4 channel
MTX 40 watts X2 bridged power 150 watts
MB Quart 6.5 front speakers w/crossovers
KICKER 6.5 Mid range Rear speakers
MTX 10in SUB In Q logic box
Factory Options on SE-R
Moonroof
Moonroof wind deflector
Center padded arm rest
splash - guards
Miles on the car, are less than 36000miles, I broke the speedo installing a white face guage kit, and replaced it with a junkyard 96 200sx SE-R gauge cluster that shows over 70,000 miles on it.
asking price $9500
This car is being sold at JGY customs, you can call JGY customs for more info on the car, or you can PM me.
There will be pictures posted up on JGY website in the next few days.
If you would like to see the car you must make a appointment with JGY Customs.
