lack of sr20 owner
I have had my Fidanza in for about a year now, but its only been driven for about 5-6 months. I recently blew my ACT clutch, and was wondering what I should do about resurfacing the flywheel?
I believe it has replacable friction material, but has anyone ever done this?
Or should I not even worry about doing this because the car wasnt driven that much??
i dont know what to do :confused:
Garage Queen: 91 VG30DETT
1yr of use is nothing compared to the stock that lasts 100k miles or more. i don't think you can resurface them. you just throw them away and get new ones (maybe after 60k miles).
shift_boost
you can replace the friction material but i think i remember it being over half of the price of the flywheel.
i would just use my judgement on the flywheel. does it look like it needs replaced?
www.FAIRTAX.org
Not true. You can replace the steel friction surface on Fidanza flywheels. Your should still be ok though since it didn't see much use.
lack of sr20 owner
i'll hafta take a closer look at it and determine if it needs help. Im hoping its not all scratched up from the broken clutch disc, the spring popped out and a piece of metal were floating around in there.
