Just give Gates a call. they seem to be reall good belt. they are the ones that come wiht UR pulleys.<font face="Verdana, Arial" size="2">Originally posted by AutoSE-R:
Hey everybody, I wanted to know what all I should get as far as belts, hoses, and such? I finally got my new engine and will be putting it in this week. So I wanted to do that stuff while it is out. </font>
Speaking of Unorthdox, make sure if you get their crank pulley that the timing marks line up with the stock crank timing marks. I have a hard time setting my timing because it seems as if my pulley set is 5 degrees off. Where it is supposed to be 15 degrees it is actually 10.<font face="Verdana, Arial" size="2">Originally posted by RPWSER:
Ian, he didnt say he was getting pulleys, just belts!<font face="Verdana, Arial" size="2">Originally posted by Pretty White:
Speaking of Unorthdox, make sure if you get their crank pulley that the timing marks line up with the stock crank timing marks. I have a hard time setting my timing because it seems as if my pulley set is 5 degrees off. Where it is supposed to be 15 degrees it is actually 10. </font>
