1 - 11 of 11 Posts
I ran my Se-R with a GTiR swap front mount cobra MAF and full 3 inch mandrel turbo back. I was on the stock SE-R wheels with Kuhmo ecsta 716 HP4 185-60R14 this obviously became the limiting factor of the night. I was running a homebrew (toluene) mixture of about 100 octane. My first pass was made at 13psi R/T... .888 60'... 2.524 330... 7.069 1/8 T/S... 10.171/82.19 1000... 12.755 1/4 T/S... 14.882/106.89 I experienced alot of wheel spin and hop so for the second run I turned the boost down to 10 psi and launched from my 900 rpm idle R/T... 8.31 60'... 2.562 330... 6.525 1/8 T/S... 9.528/84.11 1000... 12.072 1/4 T/S... 14.197/107.23...
I'd like to know what you guys think about these time from a rookie drag racer on stock wheel and tire size. Also if I were to get a set of slicks what type of times could I produce with my 107mph trap??
Yes it's tuned well. What tires are you running those times on?? Also a DE even at 7psi is pumping out alot of power with it's 9.5:1 compression ratio. As far as the VE race is concerned sure I'll race you on the highway from a 30 roll.
· Only Car in Cali W/ Rust!
yeah you should be running 13's with that trap definately. Get some wider tires, some suspension and you'll definately be down in the low 13's. The 60 ft time is horrible. Work on that, down to about a 2.2 at the worst and you'll get better times for sure. I ran a 13.3 @ 107 with my bbdet with a 2.27 60'
Did you run at Cecil Co. last weekend? A 2.5 60' is not very good, try not flooring it until you are deep into 2nd gear. With a 107mph trap, my best ET was a 13.3. We should get together and run sometime, I'm trying to make if to Cecil for the opening Saturday, the 13th. I have to pull the trans and get it back together though, so I'm not sure if I'm going to make it.
· Undecided
B-MoreNiSmO said:
Is it tuned right. I know peolpe runnin sr20de turbokit at 7psi with those times
and I should not be able to out run you .Pratice your launch
Good luck another VE just ran 13.9 on stock cams. Watch out world here we come.
And I ran 13.9 on Stock boost with a T25 :tongue: 107 traps are good for very low 13's on a good launch.
with my gti-r set up i ran 12.4 at 119mph
1 - 11 of 11 Posts
