I ended up buying a DET ($1200.00), selling the T25, manifold, injectors and IC ($700.00), then upgrading to the FMAX manifold, T3/T04E, Cobra MAF, MSD injectors, but I still ended up needing to rebuild the DET once I got it. I figured it was worth it to ME, because the DET had lower compression and could handle more boost. Then I sold the stock DET T25 and other items, so I only spent 1/2 of what I paid for the DET. I think another option is to look at buying a Japanese Spec DE(10:1)and put it in you car and then add an FMAX kit. Your cost will be low and you will have a low mileage motor. Don't worry about the 10:1 compression ratio too much. 1/2 pt of compression will not change the fuel/ignition curves with the JWT ECU. Just some food for thought.
Louis Anaya 1992 Sentra SE-R Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Kuhmo 205/40/ZR17 Tires
