1 - 8 of 8 Posts
merely a flesh wound
Are the front shocks interchangeable between B13 & B14's? I know that KYB lists different part numbers for them, and that this has been covered a million times, but I can't find it anywhere.
Thanks,
Chris
Turd Furgeson
What's up chris? It's been awhile. I see you got those rims you wanted. I think the shocks would fit. I see no reason why not. Now somebody who knows more than I go ahead and slam away for propagating SE-R myths
silversx said:
why don't the back ones work?
Rear suspension is *completely different* between the B13 and B14. Independent rear suspension on the B13 vs. Multi-link beam suspension on the B14. There's also no way to retrofit it, either.
--ATP
silversx said:
why don't the back ones work? i can get a set of 4 kyb agx w/ low miles with lowering springs for $100!!!!
Damn you! I'll take them in a heartbeat if you don't want 'em.
Chris
The B13 are almost 3/4" shorter above the spring perch than the B14, this allows for more travel. I have been using B13 on my B14 for over a year and they work great.
1 - 8 of 8 Posts
