Boost Junkie
Best way to reach me is via email (thagr81_us [at] hotmail [dot] com) or PM. Thanks for your interest in advance!
The first part I have for your consideration is an APEX'i Auto Timer AKA Turbo Timer (APexi Turbo Timer). This unit is complete with all instructions and worked great on my SRed S14. The connector for the adaptor harness was cut off so the unit will need to be hardwired into your ignition switch wiring. Not a big deal and only takes a Voltage Test Light to find the right wires on your ignition. I can supply the original box to the buyer as well if needed... This is the REAL APEX'i Auto Timer and not one of the recent knock-offs so buy it with confidence in its quality. Asking $75 FIRM + shipping on this unit.
Lastly I have for your consideration an APEX'i Rev/Speed Meter (APEXI Rev/Speed Meter). This unit is also complete with all instructions and required install equipment. This unit can be used to remove the speed limiter on your car, measure maximum outputs for RPM, Speed, and Throttle Position. If used in conjunction with the G-Sensor APEX'i offers it can also measure maximum G-Forces in the turns or for acceleration/deceleration. As with all the others, the original box can be supplied if needed. Asking $160 FIRM for this unit.
Boost Junkie
Discussion Starter · #2 ·
Turbo timer has been sold and shipped out... RSM is still available.
