1 - 14 of 14 Posts
I have one brand new, not rebuilt, T3/T04E turbo and brand new log style manifold for sale. I bought these for my own use, but have decided to go with a smaller turbo with less output. Turbo includes 12psi internal wastegate & new oil flange gaskets. This setup should top out around the limit of the stock tranny gears, about 300WHP.
Specs:
Compressor: T04E 0.48 A/R with 50 Trim inducer wheel
Turbine: T3 0.50 AR with 57 Trim exducer wheel (clipped Stage 3)
Log Style Manifold with external wastegate flange ($8 plate will block off for use with internal wastegate). Manifold has been coated with Thermal Ceramic Coating.
I am not a vendor so I'm not trying to make a profit on these. I'm asking $850 for the set.
I'll even throw in a free used intercooler to whoever buys it. I have pics of the turbo, and will have pics of the manifold in a day or two. Email [email protected] for high-res pics.
From Miami to New York
What brand turbo? Turbonetics? Garrett?
Which manifold, the Protech manifold?
WOW 12psi internal wastegate, **** I dont think my car can handle all that power.....not yet anyways
The turbo was assembled by Shockley Performance from new Garrett component stock (Garrett themselves still refuse to assemble hybrids for resale).
The manifold was made by a local company named forcedfab. They are a small shop based in Moraine, Ohio. The manifold is similar in design to a Protech's log style manifold. The welding quality is good, but the assembly is not perfect. There are a few internal spots that should be finished with a die grinder for best performance. It is, of course, in perfect working condition as is.
New Prices:
$475 for Turbo
$350 Manifold
$725 for both
Plus I have a nicer IC to throw in now as well. It is a FMIC that should be sized well for great throttle response and low pressure drop. This FMIC should sell for about $200-$250 if you want to turn it around and recoupe some of the turbo cost.
actually, yes.
PM me with what you got. I still need a DP & BOV too.
Discussion Starter · #10 ·
Trade pending with 91sentragtir.
Will update in a few days.
Discussion Starter · #11 ·
91sentragtir hasn't responded to my PMs so all items are still available.
Discussion Starter · #14 · (Edited)
Sandman purchased the combo, but I am buying the manifold back from him due to difficulties w/installation.
Turbo is SOLD.
Manifold is still for sale, but a bit of info has changed. Sandman had difficulty installing it on a classic. Seems the turbo was hitting the block.
Manifold should fit RWD applications and could fit FWD applications with modification.
1 - 14 of 14 Posts
