Gnet Member
Ok im going to try this one last time before it gets parted out. If you think this vehicle is overpriced please just move on, many of the individual components on this car are worth more than the average G20. Please don’t say “don’t”, im not in a position to finish this build and just want to get out of it so someone can finish and enjoy it. Currently Management and Engine wring are removed, leaving an open canvas for the new owner to use the engine management of their choosing. I will include with the sale any and all misc parts that I have leftover, which is quite extensive. Current Engine and Trans Mileage is 0 miles since rebuild, about 45min to 1 hour runtime. I can deliver anywhere in the US but buyer will be responsible for costs associated with delivery. Pictures were taken today 4/17/2016. If you have a reasonable offer lets hear it.
Price: 6500 OBO
1991 Infiniti G20
Engine/ Transmission:
00 P11 5spd Trans
Clutchmasters FX500 Clutch
TWM Short Shifter
Skunk2 Weighted Shift Knob
Custom Rigid Shifter Support Rod/Box
54C Head/Block
ACL Rod, Main, Thrust Bearings
ARP Headstuds
VE Metal HG
Manley H Beam Rods 19mm Rod Bearing Machining
JE 8.5:1 Comp Pistons 86mm bore
Turbo Setup:
Custom T3 Log Manifold w/Tial V-Band
Custom 3” SS Turboback
Custom SS Wastegate Dump
Precision Billet 6262 w/ Custom 3" VBand Out
Tial MVS Wastegate
Mishimoto M Line Intercooler
Synapse Synchronic BOV
2.5” Hotside IC Piping, 3” Coldside IC Piping
Custom Short Runner Intake Manifold w/ IAC
Q45 Throttle Body
Push-Lock Boost/Vac Lines
4” Intake w/K&N Filter
Fueling:
1200cc ID Injectors
Custom Rail
-6 AN Fuel Lines
Aeromotive FPR
Walbro 400lph Fuel Pump
Ignition:
S15 Coilpacks
20v Cam Angle Sensor
Engine Cooling:
Custom Radiator w/ Mishimoto 3-Core
Custom Block Mounted Surge Tank
Custom Coolant Overflow Tank
-20 AN Coolant Lines
Management/Gauges:
Innovate MTX-l Wideband
AEM EMS4
AEM Water/Meth 1 Gallon Kit
Electronic Boost Control
ARK MFD Display
Engine Accessories:
Custom Catch Can w/Panel Filter
-10 Crankcase Vent Lines
Custom Power Steering Resevoir
AN Power Steering Plumbing
OEM A/C Compressor
Odyssey Race Battery
Chassis:
Loco Poly Pass and Trans Mounts
Loco Nylon Front and Rear Mounts
Unisa Jecs Xmemeber Bushings
P11 Xmember
Ksport Kontrol Pro 14k Front 12k Rear
Superpro UCA Bushings
Energy Suspension Complete Suspension Poly Kit
P11 Brakes w/New Rotors and Pads
Modified Third Links
Interior:
Complete Touring Swap in Excellent Condition
R32 steering wheel
EGT Cluster
Pioneer Deck w/Bluetooth
P11 Bose AMP and Speakers
Auto Dimming Mirror
Trunk Mounted Water/Meth Tank
Exterior:
Gtir Front Bumper
Gtir Grafted Hood
Shaved Antenna
Euroforma Sideskirts
JDM Amber Corners
EUDM Tails
Autech Wing
Rally Armor Mudflaps
Yakima Roof Rack
Metallic Cement Gray Paint
JDM Rain Visors
Volk Te16 16x8 Front 16x7 Rear
Hankook Evo V12 Tires
