You can use those on a NA gas engine?
I know about using them on TDI (diesel) setups, but I've never heard of them on regular engines.
Heavy Breather said:They can be used on anything! If you hook the Hobbs switch to your vacuum system it will actuate a a preset boost allowing crazy boost on pump gas. Also, if you know anything about propane, it gets down to like -30 when changing from liquid(bottle) to gas(discharge) the trick is to get it as close to the nozzle as possible for best chilling results. Its kinda like nitrous and fuel all in one tank.
