I may be interested in one. These are the ones with the ceramic wheels & shafts right? Email a pic when you get them.Domiken said:Guys my friend just swapped in a RB26 in his 240 and has 2 ball bearing T28's for $400 each, NO SHAFT PLAY! Motor came clean as hell from Japan.
Will be posting pics soon
Thanks for the info, the motor came off an R34 Skyline. The oil and water lines (or what it looks like) are still hooked up on the turbos. Ill see if I can throw in the turbo outlet pipe flange (if I can find it)cmng said:just a little info. not to disturb the sales
OEM GTR 32 and GTR 33 RB26DETT turbo is non ball bearing
only from R34 is ball bearing
and it is T28 but small T28, utilising T3 compressor housing
compressor housing and wheel even smaller than S14
Turbine wheel is same with S14., i forget the full spec.
i have the detailed turbo list from GTR32 to GTR34 turbine spec and N1 as well 400R turbine spec
may be can be used for future reference as well in the forum
will update on monday since it saved on my office pc
